thinfourth
pleb
- Stonehaven
In our house we have an occasional issue where we run out of hot water.
We shouldn't as we have a 200litre unvented cylinder which is fine.
It is heated by an electric immersion and a dedicated circuit from the oil fired boiler.
The immersion is fine and the boiler is fine
however
The tank is feed from our own well via an electric water pump which gives an utterly excellent pressure and flow. So excellent that we once bought a cheap and nasty showerhead and it split down the middle.
I like long hot showers, the wife likes long hot showers, the wife uses huge amounts of hot water in the kitchen at times.
So about once a month one of us ends up with a cold shower as the hot water runs out.
This is a issue with the users not the system
I am considering modifying the system
for about £50 you can buy a small stainless steel plate heat exchanger
What i am considering is taking the feed to the heating coil and breaking into it before it enters the tank.
Fit the heat exchanger into this line and then pipe the tank outlet into it and then onto the house.
Then of an evening when the heating coil is on and we are drawing hot water if it drops in temperature then it will get a boost from the quite warm return leg going to the boiler.
So i have a sort of combi boiler effect going on.
Is there a reason this won't work?
The snags i can see is this is unregulated temperature wise so you could potentially get hot water at the boiler circuit temperature instead of the hot water tank temp. The shower is thermostatic so it can handle this.
Or i could use it to warm up the water entering the tank which would solve the overheat issue as once the tank comes up to temp it will shut off the heating circuit via the motorised valve.
however
