normspanners
how about putting the PHE in the hot line from the hot water tank, therefore boosting the temp of the already hot water to near boiler temp,( NOT BOILING btw) then you would not have to use quite so much hot water, as you would be mixing more cold to attain the same hot shower, as said I run my immersion at 80 deg and can get 5 showers out of it, one after the other plus modified hot fill washing machine! and doing it that way it wouldnt affect any other circuit, yes you have to be careful in the basin and sink but we are well aware of it, I placed my DHWT centrally when I designed the system and the longest hot run is about 12/15 ft of 15mm and 5ft of 22mm, It also means when we run a bath you turn both the taps on equally and start getting undressed etc and by the time you are naked got your towell ready etc the bath is full of the correct temp water ! I can come in freezing enter the bathroom and be in the bath in 4/5 mins.Or i could use it to warm up the water entering the tank which would solve the overheat issue as once the tank comes up to temp it will shut off the heating circuit via the motorised valve.
