brewdexta
The biggest tool in the box
- UK
Old decals tend to decay over time. Hot water/steam usually just shrivels them and then they fall off, or shatter into a million pieces. That design wouldn't be too hard to make on MS Word or Paint, sheet of transfer paper and you'd be away.
Interesting on that last pic, there's a sheet metal shroud around the entire motor drilled into the casting.
I hadn't noticed the shroud before. I wonder if that was standard a option, it looks like it bolts to the back of the head casting and there are no signs of holes there on the three castings I have.
Good call on creating a new label
this took me a couple of mins, probably needs aspect ratio and font tweaking when I get to measure it up in the flesh but takes seconds.Cheers
Andy
Probably move "in" to the second line too, so that there isn't as much white space on that line.
I think I may leave as is given I have already printed one off, only on 80g standard inkjet paper though, I was thinking of maybe a bit of photo paper would be better.
