The_Yellow_Ardvark
- Going Away.
Or a low slung shifter.
@dazza Never heed them Darren, a few whacks with a lump hammer should dislodge most of that dried-on cement.
asked the lady if i could have it and she said no
Already knocked the cement out, pumped up the tyre and put it to use cleaning out some flower beds. Well happy with that don't know how i lived without one.
Couple more shots -
Picked up off Trade Me from a guy in Auckland. Going to take legs off and make a trolley for it. Cuts great just needs a bit of tweaking to get it to cut square, think a lot is getting feed rate right, also there is a grub screw missing from blade adjuster so blade might not be sitting square.
Here's mine on its trolley. If I use like that is does shimmy a little, but I've made a paddock stand type of thing to go under the back pair of castors. Works a treat.Better off just making a dolly or such for it to sit on, if you plan on moving it around. As mentioned though, wheels aren't a good thing with something like that unless you can retract them else lock them solid. Bolting the feet to a couple of lengths of wood, to make something like a sled, would be a more stable option whilst allowing it to be shifted fairly easily.
Could make it look like a 1967 Vespa?And don't forget to weld on some brackets for a horn and rear view mirror before painting.![]()
and I don't need a power hacksaw...
And that's relative........how?![]()
