W.olly
- Radcliffe, Manchester
Very little done as work is slowly killing me and to tired to do much in the last week or so. Still lets see whats been done.
Lets see then
I made a panel to cover the rear of the main fuse box and also the water level indicator.
This is removable just incase i need access.
Just a panel of 4mm Sapele veneer so as to match the rest of the heads/cupboard.
Water level indicator window, i still need to make a backing for behind the tube.
For a while i was wanting to use a laminate the galley splash back around the window and cupboards but after much debate as what to go with i/we decided to just continue the Sapele veneer. I managed to do a little around the window but thats it as i need to order another sheet for the rest and more Hockey stick for the trim around the window.
Oh yes, a few things i got arrived the other day aswell. Love the helm wheel and the horns are full SS, most are plastic and SS and as i am picky i got these second hand for a good price.
To make the risers around the cooker i needed to rip down a 105mmx27mm length of Iroko, and me being me i thought i may aswell by a table saw, cheap mind you. So then i can do that and make the light holders for the cabin
And not to forget a cabin step out of Iroko also if i have enough left, i could of gone to a joiners and ask then to do it but for what i paid for the saw why do that.
I had to make a stand for it too.
Only thing i needed to do was get a new blade for it and as it has a small 1/2hp motor it just did it with a steady feed through. Although it has done the job i have removed a 3hp 2800rpm motor from one of my compressors to use. Just make things that bit easier. Only thing to do is get a new pulley as the one it is fitted with has a 5/8 ( 15.87mm ) spindle and the new motor is 19mm.
This is the finished cut of the risers.
Lovely grain i think
This the sections for the light holders
I couldnt decide how to have the risers until T made a comment that they need to be low enough for the pans to sit on the hob. I stated with these. way to high.
Then down to this after a much faffing about.
These will be covered on the inner side in brushed SS and go up the back to the light above.
Now then, cabin light holders. I made these as the lights i got are not easy to remove once fitted in place due to the grips they have. These holders will be screwed in palce then i can remove them to remove the lights if needed. I got 60mm fitting lights so if i ant to replace them i can easy find a new set.
These are cheap lights at £26 a set of eight. May not last long but still we will see.
Started with a large hole saw a went through at the lowest speed the pillar drill can which is 500rpm and only halfway as the pilot hole will be used next for the 60mm hole.
OOpps i forgot the 60mm drill pics but you get the drift.
To clean them back i fitted a flap sander to the pillar drill and moved the bed up close to it so then i had this to ease the job.
Near finished product.
I wanted a larger diameter holder by another 12mm but that was the largest hole saw i had therefore i need to make three little seats for mounting screws in the edges at a 45 deg angle.
In the last few days besides the cabin big lights arrival also came the cupboard lights and door switches which i will fit asap. I cant decide on what eyeball light to get so here i think i will go with one of the cabin lights and get a seperate switch for it. Above the worktop there will be a small LED strip.
Infact these are what i have got. So one in each cupboard and one above the galley.
And the berth lights that arrived.
Thats about it for now. Think i will have a go and see how the helm wheel fits this week, ah its dark after work, mite have to fettle a light on the deck now lol.
Lets see then
