God mode restorations
- uk colchester
Sorry. Got confused. Picture is tool post. It's only a fraction bigger but will work with a little fetling.New tool post, I missed that, which one?
My plan is to drill the centre hole out to 13mm. This will match my new post stud. The stud will have a 5mm thick washer machined in to it. One end will screw in to the top slide and the washer will be drilled and pinned . This will stop the stud from turning when undoing the the top nut. If that makes senseSorry. Got confused. Picture is tool post. It's only a fraction bigger but will work with a little fetling. View attachment 122820
Not really sure what you mean but the Glanze tools are decent. Not quite as good as the big names like Sandvik, Kennametal, Seco, Iscar etc but much better than the cheap stuff that others sell.As regards to glanze lathe tooling. Are these good at different rates of speed.
I mean I did some experimenting and found that some tools didn't perform to well at a low turning speed and some were ok.Not really sure what you mean but the Glanze tools are decent. Not quite as good as the big names like Sandvik, Kennametal, Seco, Iscar etc but much better than the cheap stuff that others sell.
OK . What inserts would be a better choice.The inserts will determine what you can get away with speed wise. If you have a reasonably sharp geometry with a small nose rad then it will handle most speeds from slow to fast. The only thing is that inserts with these features tend to be weaker so pushing them hard would likely cause chipping. That however is not going to be an issue on a small lathe.
I would however suggest you get better inserts, the Glanze supplied ones work reasonably well but they are not in the same league as big name ones.
OK awesome. Thanks for your help.It kind of depends on what material you will be predominantly cutting as you get grades for specific materials but they will usually also work fine for others, just not so good.
Korloy are decent and fairly reasonably priced especially if you wait for the special offers Cutwel has a few times a year.
@Richard. got some from Cutwel, not sure which he ended up with but I think he liked them.
Understatement there. He loved them!!!liked them.
people think if its on e bay its cheapI used to get a lot of my inserts from eBay, Sandvik Kenna. Mitsubishi etc but nowadays they are often more expensive on eBay than buying from tool suppliers.
do there homework and it isn't always the casepeople think if its on e bay its cheapdo there homework and it isn't always the case
Aye. But sometimes the more expensive eBay item works out cheaper with free post over ridiculously priced couriers. Always pays to shop around no matter where you usually buy.I was needing some IP67 plugs/sockets for wiring on a sounder on a boat, looked on eBay and found the perfect ones. There were quite a few different sellers with them but all were within a £ or two. Before I pressed the button I did a google for the part numbers. I got a hit from RS Components and thought I would check to see how much RS would be ripping me off, just about dropped down, RS were less than half the price people were selling them for on eBay and RS are not what I would consider the place to look for rock bottom prices.
When i was using rs as a main supplier the service was very good on more than one occasion if an item was missed off a big delivery or needed for a breakdown they have sent a bike courier down from Corby direct.That is one great thing about RS, next day delivery and free, but yes some places are a bit steep for the couriers.
The biggest problem nowadays is trying to find what I want on the website, I come away wanting to scream.
I would happily pay for a set of printed books if they were to start printing them again.
You can search there site with Google. Use this all the time. Screwfix search engine is terrible. This makes it usable.Yes I agree with that but what I have found is Google is actually quite a good search engine for RS if you know roughly what you are looking for. Was trying to find a miniature E-Stop switch for my pendant on the plasma, had one previously and knew it was by Omron. I searched and searched on RS and couldn't find it, punched it into Google and up it popped from RS![]()
https://www.google.co.uk/search?q=u...ndroid-google&sourceid=chrome-mobile&ie=UTF-8
It’s dead right.people think if its on e bay its cheapdo there homework and it isn't always the case
