Nice job Brad. I get plenty of those to do in the summer months from my mental track matesStill working fine on AC.
Honda RS Two Stoke Swingarm Repair
7020 Alloy. Constructors manual recommends 5356.
First photo shows the damage previously repaired. Not sure what happened but bike has taken a proper knock at some point. Done with a MIG.
Second photo I ground the mig weld off and dye penetrant tested.
Front weld was fine and found how far the cracks went so got the carbide burr out and got to work.
Last photo is end result in the back.
@Xup sorry this is the thread with all the bits done with the Handytig the other thread was aimed more at the Micorstick
Unless it's specified in the manual I would not be bridging any pins together in the machine or torch.Cheers Brad, Sorted it,....took the supplied Lorch torch plug to bits, for others it might be of help so.....from the locating tab on the socket on the front panel, it goes clockwise 1 to 5, 4-5 are the last 2 before the location tab.
I jumped/bridged 4/5 on the front panel socket problem gone... been welding Alu for the first time ever, well pleased. weld puddle is so much easier to see, but it also runs away from you very quick.
That's good mate. So long as it's in the manual you have no problems.Its in the manual Richard, error E05, " torch monitor in gas cooled operation/ incorrect torch connected(water cooled)/Use gas cooled torch(recognised by bridging between the contacts 4 and 5 on the torch plug) "![]()
So as I see it if I wanted to go water cooled I'd have to do the same by bridging the pins, if using a foot pedal as there will be nothing connected to the front panel torch socket.
Pins 4 and 5 are connected together in the supplied Lorch torch plug.
