good idea but it would pull the guts out of a cordlessId make a die holder up to fit in a cordless drill.
I use a cordless for tapping M12 all the time. Its a decent one, in low gear mind.
They're cheap..........I just tried manually running a 1/4" BSP die down a piece of 12Ø MS round bar, and it barely scratched the surface let alone cut a decent thread.
Those die holders pictured above look the business ............ would anyone care to turn me one up? ...... beer tokens are awaiting
25mm internal depth clearance from the back of the die, 3 grubscrews for the die, 3 side slots to clear swarf and a 12m hex shank (with one end turned down to say 10Ø and then welded into place from the inside of the adaptor).
They're cheap..........http://www.tracytools.com/tailstock-die-holder
Have you priced them up for someone to make them? For that quantity, you could get a real good price, especially if you don't have an urgent deadline - the saving in your time and effort would probably be worth it.
Someone may have already mentioned that threads are rolled and not normally cut.
Hey, sorry, I posted that on my phone so I couldn't go into detail and I didn't notice that Gareth doesn't need the threads to be strong.Who told you that? Threads are rolled but they are cut equally as often and more so in most engineering shops. It's about application and cost. Please check your source of info before posting stuff like that. This is how incorrect info gets out the net, people read it and think its true. It makes the guys like me, life long in the trade cringe, at all the misinformation spread about.
Quick Google says that commercial male threads are rolled, female threads are cut. That finally explains why it's always the nut that shearsHey, sorry, I posted that on my phone so I couldn't go into detail and I only cursively read the post so I didn't notice that Gareth doesn't need the threads to be strong.
Cold forming of materials like threads is year one engineering, so I wouldn't normally reference something like that. I've only ever seen cut threads on small volume special parts and on large diameter studding (which even feels sharp in your hands). Cut threads will be weaker so it makes sense that they would not normally be used. This was confirmed to me during projects, I recall a chassis designer telling off a technician for cutting threads, and my machinist also avoiding cut threads stating same reasons. I am talking about male threads here, I don't know about female threads.
This second die will be my M12 X 1.75 X 1½” in a suitable handle: alas the 1½” die holder that also arrived this morning has a 16Ø hollow shank and although it allows 12Ø bar to fit through it will not fit into the 13mm chuck of my cordless drill.
