MattF
- South Yorkshire
yea but look at your location![]()
Honestly, anyone would think Yorkshiremen were tight. No idea where people get that idea from.
Honestly, anyone would think Yorkshiremen were tight. No idea where people get that idea from.![]()
ok beat this one....when my 13 amp fuses blow i put them in my lathe and put a pin drill through them and solder a new 13 amp wire in them,blob of solder each end and i have a new Yorkshire fuseWe've been through this, just last week I spent 3 hours removing a diesel tank before my van was removed, got nearly a whole litre of fuel
That is not tight, that is being smart
..not joking either
ok beat this one....when my 13 amp fuses blow i put them in my lathe and put a pin drill through them and solder a new 13 amp wire in them,blob of solder each end and i have a new Yorkshire fuse..not joking either
Is it possible to resharpen blunt chisels?
Yes except I split the fuse lengthways and solder it back together, have you seen the price of fuse wire?????
giz a clue where u buy the 13 amp wire fromok beat this one....when my 13 amp fuses blow i put them in my lathe and put a pin drill through them and solder a new 13 amp wire in them,blob of solder each end and i have a new Yorkshire fuse..not joking either
I have a bag full of the old carboard type holders and use something thats roughly the same thickness...i started modding fuses this way a few years ago when my plasma kept blowing 13 amps on full power so i re-filled them with thicker wire and no more blown fusesgiz a clue where u buy the 13 amp wire from![]()
Not recomended i know but sometimes you have to dig deep to get by
it would be 16 amp wire, i know someone that just solders it across the blown fuse direct on to the holder as well . less loose conections the betterI have a bag full of the old carboard type holders and use something thats roughly the same thickness...i started modding fuses this way a few years ago when my plasma kept blowing 13 amps on full power so i re-filled them with thicker wire and no more blown fusesNot recomended i know but sometimes you have to dig deep to get by
better than a mig tip anywayit would be 16 amp wire, i know someone that just solders it across the blown fuse direct on to the holder as well . less loose conections the better![]()
You could always make some suitable wire the old fashioned way Brightspark. Throw a penny in the air between a Yorkshireman and a Scot.![]()
oops, I meant to say blunt filesIs it possible to resharpen blunt chisels?
