What sort of weight do you hope to move?It was. I should perhaps get an hour meter on the machine to log usage. Any recommendations?
Blades are a bit nicked all over but still chipping well, might turn them around and get some spares, but perhaps better as its not so agressive pulling stuff in.
I thought I was going to have issues with short fat laurel stubs but with a push log they all went through easy.
I'm a bit sore from all the lifting. Unloading chipper from car at 10pm whilst exhausted, is not ideal.
I have an idea for a miniture engine crane? Does anything exist for small engines etc.. ?
I have a piece of 12mm thick stockboard that I slip into the boot , a few inches in over the edge so I can roll things onto it and slide heavy stuff out the boot on to a reinforced trolley then into the garage for hoisting up and installing on a bigger, stronger trolley or the welding bench .
I have my fully fitted removable 90 kg 12 volt disabled buggy lifter to also help get things out , which is a boon some days indeed.
