Hi, second ever weld and to be fair the 1st wasnt that much better. It is much harder on the car vs off.
I know it's messy but why am I getting lots of little bubbles - top left is most obvious as ground back elsewhere? I wire wheeled both areas and messed about with my settings. I tried cranking the gas right up. I wasn't able to get to a confident conclusion on what would fix it.
Its a mig with 0.6mm tip and argon/c02 gas.
My CFM dial started with 4 and went to 2 on trigger but I tried it at 10 going down to 6 on the last weld on top right.
. if you can pull line then try downhill is more easy , you should not to weld like that but is best way hhow to lear welding from scratch ..
