I have brought from this company before and have been very please. I have been thinking I mite buy the same unit as yours soon.I have had this one from SGS since Sept 2020 and used it on my motorcycle engine. https://www.sgs-engineering.com/ssb100-shot-blast-cabinet
Worked very well and cannot fault it at all, noticed that is has doubled in price since I bought it nearly 18 months ago
Will take a look at what upgrades/mods are available.
If you need me to measure inside my cabinet, let me know and I will look later.Will get the tape measure out over the suspension bits and see if this size is large enough. Should be I think.
Well, no, not for a chassis or tank turret they're not. But for most suspension parts they're ideal. And that is what the OP is looking forthe small cabinets arent much use and limited in size using a suction gun .also no extraction on them
) and the gun clogging up. That problems seems to have gone way now.I have been eyeing up the same , what size / type of aggregate do you use , as even if I look at glass media , there are different size options .I have had this one from SGS since Sept 2020 and used it on my motorcycle engine. https://www.sgs-engineering.com/ssb100-shot-blast-cabinet
I use medium aluminium oxide with my wee blasting pot, work a treat and can be reused.I have been eyeing up the same , what size / type of aggregate do you use , as even if I look at glass media , there are different size options .
Cheers
Acetate filmBought my generic one for £35 ….it won’t wok he said…a nice clean out and away we go….
mines not modded as it does well enough…it’s about 800 mm inside length….
only prob is the medium gets damp…..the base of mine is now covered and has a saver fluorescent bulb bulb running 24/7 when in regular use….
as for medium I have two sorts….kiln dried sand from the builders merchant…..
and worn out sand for the softer jobs…..
big jobs I have a big pot driven by a road compress….
lastley don’t expect it to work well on a Lidal type compressor…even a two cylinder Clarke special will struggle…
Also given up on changing the Perspex…now just guess n lift the lid occ….
never found anything to protect the perspex
