Never dealt direct but used to do some work for Hovis who had Eriks onsite. Are they reasonable or extortionate?My go to for all things o-ring related are Eriks. Just about any size/shape/spec you could need.
Thanks.
I can line tins well enough but the O ring makes it easier. It'd need to be food grade and is it possible to glue silicon? I thought one of its properties was that not much stuck to it.
Same sort of area as Trelleborg really.Never dealt direct but used to do some work for Hovis who had Eriks onsite. Are they reasonable or extortionate?
I've got some lovely asbestos packing here.
Neither is old brake tubing haha!not food safe tho is it.![]()
Silicone o rings will only do 150-180° As far as I know. Viton May be better?PTFE is not a good O ring material. It is not an elastomer, so tends to suffer permanent deformation rather than conform and then bounce back. For food-safe at 200'C, I suspect that silicone and EPDM may be the prime candidates. Kalrez might work, but weight for weight it is more expensive than gold.
Viton is a good rubber, but it's this food-compatible need that I've never had to deal with previously, and I don't know if Viton is good for thatSilicone o rings will only do 150-180° As far as I know. Viton May be better?
FFKM I would go forViton is a good rubber, but it's this food-compatible need that I've never had to deal with previously, and I don't know if Viton is good for that
You could take a used one and cut it in half and see if it is hollow? I've used metal O rings for really high temperatures that were made that way; to a limited degree, they too compress in a returnable way (damn clever!). I've also seen rubber O rings with a transparent layer of silicone on the outside; cannot recall where they came in.These ptfe ones are quite springy, I don't know if you get different types of it? Or if they are mixed with something else?
