I suppose it all depends on the welding experience you have had, the equipment you have access to, the type of work you need to weld up and where you are going to weld. I own ARC, TIG and MIG, the majority of my welding is with MIG, which I can weld using 0.6mm wire up to 1.2mm and even 1.6mm wire however I have never had a reason to use that last thickness.I generally use 0.9mm unless the metal is either thin or thicker, Never had trouble with penetration using MIG. I regularly used to weld from 2mm up to 20mmm and choose MIG, under 2mm thick steel I use 0.6mm wire) MIG, it is much faster to tack and weld a job, with less cleanup. You also need to factor in the cost/rental of the right type of gas and gas bottle, a ARC welder is also much cheaper than an equivalent sized MIG to buy.
For home use, most homes do not have more than a 10amp GPO for electricity so very limited in the type of welder you can choose and get weld amps and voltage out of. So most are limited to 130 to 160amps? In that range an ARC welder would be better as you can use 1.6mm electrodes (if you can find them) 2.3, 3.2 ( and 4mm rods which can be used for thicker steel however your 10A amp MCB will trip after a minute or two). Similar results with MIG but on a 10A circuit you will have to watch the duty cycle on both types, an equivalent sized MIG welder will give similar results if you know what you are doing, a pretty weld does not mean it is a strong weld with good penetration.
Having said all, that I can pick up my single phase 180A inverter ARC welder with one hand where as the MIG is 3 phase and with bottle and trolley weighs close to 250-300Kg. So at the end of the day you need to use the right machine/process for the job at hand. Most Factories will use MIG for most of their welding jobs right up to welding 100mm thick steel, I won't be getting into dual shield, submerged arc and all the other tech available.
