Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
I often hear it stated that "Arc is better than MIG for welding thick material"... But I've never seen a comprehensive justification for that statement.
My personal experience is that:
- If you can position a weldment in a way that let a you use MIG in Spray Transfer, it's normally the best option.
- Welding out of position, like on pipe spools that can't be done on a rotator or field fit and weld applications, an all positions Dual Shield (in the workshop) or Flux Core (in the field) wire, gives both the higher productivity of wire-feed welding, and the practical advantages of Arc using rods with a fast-freezing slag.
- Arc only really comes into its own for field applications where you're working around restrictions on the input power supply, or physical size of welding plant that you can get to the job. Those applications are when the comparatively greater "heat" and arc force for a given amperage, offered by Arc will allow you to get deep penetration in a situation where Wire-Feed processes wouldn't.
I also know sweet FA about pipeline welding (as distinct from pipefitting) apart from the fact that Arc is still widely used in that discipline, in spite of semi-automatic or automatic SAW processes gaining ground.
Having trained up to pass a C&G L3 Diploma, and BS 4872 assessment, I like to think I have a reasonable basic knowledge of welding...
But at the same time I've never worked full time as a welder, and there's bound to be on-the job knowledge I've missed out on as a result of that.
(See recent threads where I got my **** kicked welding 1mm sheet, teaching myself auto-body repair, for examples of a skills gap.)
So what am I missing?
