What's The Best Way to Weld this Socket into a 45 gallon Oil Drum?
  1. Arcangel Member
    61
    Ipswich Suffolk
    Hi Guys
    I could use some advice on Welding this Galvanized Malleable Socket (see Photo) into the side of a 45 Gallon Oil Drum
    First of all the Drum is Brand New made of Steel and has a removable lid and has never contained any inflammable substance, so providing I leave the lid off when I'm Welding the Socket in the side of it, then nothing should go bang
    The plan is to use a Hole Cutter the same size as the OD of the Socket, so it will be a fairly tight fit, even before I start to Weld it in.
    I am also planning to grind off the Galvanizing as much as I can and although I've done some Mig Welding before, I've never yet done any Welding on Malleable Iron, so don't know if this is going to be a problem?
    Also should I use 0.8 or 0.6 and what would be the best position to have the socket in, on its side or up straight?
    The Barrel will be used to hold Water, so while it isn't critical, I'd prefer it not to have any leaks when I've finished
    Any advice would be appreciated
  2. Cobbler
    Cobbler Codger bodger
    5,164
    Gloucestershire UK
    Why don't you go into a builders or plumbers merchant & buy a tank fitting, save you a lot of hassle.
  3. Shoggi
    Shoggi Member
    217
    Bradford west yorkshire
    Why don't you just drill it and put a tap on
    If it's just for water
    slim_boy_fat likes this.
  4. piman Member
    1,734
    Oswestry Shropshire
    Hello Arcangel,
    I don't know if you can but if I had to do that I'd braze it.
    Alec
  5. Cobbler
    5,164
    Gloucestershire UK
    Just looked in Screwfix, there you are, just the job.
  6. Arcangel Member
    61
    Ipswich Suffolk
    Hi Guys
    The Tank Connector idea, is something I considered but I want the Barrel Standing up on its end, which would mean the Tank Connector would be in the Curved side of the Barrel, in which case it may not be a Water Tight fit, like it would be if I put it on the Flat end
  7. Paul.
    Paul. Moderator Staff Member
    6,518
    Northampton. UK
    If you can get inside to fit a tank connector just put a flat block in side and beat it flat against it where the connector fits, you only need a small area to get a seal I've done it quite a few times.
  8. Arcangel Member
    61
    Ipswich Suffolk
    Hi Paul
    What I omitted to mention was that the Barrel will be sitting on top of another Barrel, which will be turned into a Burner to Heat the Water in the Barrel which will be sitting on top, so any rubber seals are going to melt
  9. Kayos
    Kayos Member
    5,675
    Yorkshire
    Tank connectors work fine on curved surfaces, just use a good washer, an Essex flange is designed for a cylinder and they are not curved
    eLuSiVeMiTe likes this.
  10. Kayos
    Kayos Member
    5,675
    Yorkshire
    Seals will hold at 100 deg
  11. brightspark
    brightspark Member
    30,415
    yarm stockton on tees
    have fun welding it with a mig :)easy to gas weld with oxyacetylene with different thicknesses of metal or braze it in
  12. Paul.
    6,518
    Northampton. UK
    Agreed, an essex flange is the ideal solution, great thing is you dont need access to the back to fit one, the £15 or so to buy one might put some off though, when compared with welding on a 2 quid socket.
  13. pedrobedro
    pedrobedro Man at Matalan
    10,445
    CX Derbyshire
    Use fibre washers as used in water systems the world over.
  14. Kayos
    Kayos Member
    5,675
    Yorkshire
    While this is a welding forum, welding is not always the answer.......
    hunter27, Parm and MCKDAVID like this.
  15. WorkshopChris
    WorkshopChris Forum Supporter
    4,927
    South East Essex
    Malleable iron can be prone to cracking around the edge of the weld area.
    If I was going to do this I would braze. Or use bolts and a flange or tank fitting.
    You might get lucky with a weld it all depends on the makeup of the fitting.
  16. dannyp Member
    id just weld a hydralic fitting in they weld just fine and have bsp threads on them
    Arcangel likes this.
  17. Arcangel Member
    61
    Ipswich Suffolk
    Hi Guys
    Just had a look at an Essex Flange on ebay and one was not far short of £60 with some around £15-£20 so maybe I'll try with a normal type Tank Connector and see how it goes, the thing I am Constructing is for an Outside Off-Grid Hot Water System, so its really no big deal if it leaks a bit but if it works how I'm hoping then it will be worth investing in a proper Essex Flange
    Thanks for your Help and I'll try and put up some photos if/when I get her up and running
  18. Arcangel Member
    61
    Ipswich Suffolk
    Hi That sounds a Great idea!
    There is a Hydraulic Shop down the road from me, so I'll ask them if they have one to fit the Brass/Bronze connector in my Photo but would you Weld it in with 0.6 or 0.8 ?
  19. gaz1
    gaz1 Forum Supporter
    10,711
    westyorkshire
    thats an ackward way to go via a 2 barrel system
    how much water are you intending to heat and how much wood consumption do you want to go through doing so ?
  20. mechman Member
    1,906
    great britain n.e.lincs
    Didn't think malleable fittings were much good for welding, can you use a steel socket instead?
Advertisements
