BrokenBiker
- Newport, South Wales
so, i dont like the torch on new mig...used it earlier in anger to weld a socket to a locking wheel nut to remove it without the key and the length and angle of the neck is just badly designed...its longer and straighter than any other torch ive used before which means its harder to use your spare hand to prop against, and you have to bend your wrist in weird ways to get the correct torch angle into the joint.
its a euro torch though, although has a fly lead hanging out for changing polarity but that a simple addition to any euro torch connector.
250 amp mig, would you go for a 15 size torch (same as the supplied torch) under the notion that anything needing more than 160 amps is going to get stick welded anyway, or buy a 24/25 size torch knowing it cant ake all the welder has?
i would say i could keep the original torch incase i ever needed to get in somewhere tight...but ive got a stubby gas lense kit on a flex head tig torch that would be better than a mig torch for that anyway so id probably en up using the tig over the mig.
my worry is, that ive only ever ha migs that will wel 3-4mm steel, so above that i have ha to use the stick weler, but now i have 250 amps i can see me using it flat out every chance i get as its just easier and cleaner.
