Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
You can check for nails with a metal detector
Its not nails but stones that get embedded
Crikey. I cut five or six sleepers when I did my drive with a chainsaw as I said earlier and the chain was fine. I sharpened it first, but I had no issues at all. The chain is still in use.
if need be run an angle grinder across where your cutting with a wire cup wheel and clean the crap offWell used sleepers or clean ones? I once cut up a tree that had washed down the local river and the silt that was stuck in the rough bark was enough to make a big difference to the time between sharpening. I also seem to remember catching the odd stone and needing to stop and sharpen.
I'm thinking the bottom is most likely to have the most damaging stuff embedded, I wonder if it would make a difference to chain life to cut with the bottom of the sleeper facing the saw so the chain is pulling the crap out instead of dragging it through the cut?
I cut a stump out with my chainsaw wire brushed the soil of round it and hosed it down
and don't cut crap as u said ruins the cutter bar as well which in turn knackers a new chain if u fit one to itThe other thing that people forget is cutting stuff with grit in will also knacker your bar.
It creates a wider groove so that the chain slops from side to side which means you can't get a straight cut.
I found this out the only time I lent my chainsaw out to a 'friend' who was taking out some fir trees, he felled the trees and then used the chainsaw to cut the roots out of the ground.
With some careful use of a small hammer, anvil and spacer I managed to close the groove up but it was a faff to do.
Moral of the story is never lend your chainsaw to anyone!
your own or someone else'sChainsaw should do the job, that's what we have used in the past when we have needed to cut down old sleepers, often in less than ideal conditions.
I don't buy them to knack them[QUOTE="daleyd,
I like to keep my tools in good nick as much as anyone but I don't buy them to look pretty.
[/QUOTE]@skotl Waiting for the report/pics of the 'done' job, or you away again?
Aye it might do them, but I'd easily take the cost of a new chain against the cost of a decent circular saw blade if it knackered his... especially given the thickness of the sleeper, 150mm, that's going to be a substantial circular saw table, with a pretty big lump of cash for a new blade..
The big problem with using a table saw is you are manhandling the sleepers to cut them (skotl says they are close to 100 lg each) rather than moving a relatively lightweight saw to cut them - might be easy enough with a proper industrial table saw with a roller bed but it would certainly be tricky with an average sized table saw.Unless they can be turned over and cut on multiple faces.![]()
