They won't touch them, it's not just metals that ruin a blade but embedded stones and grit and you won't find those with a metal detector.Bandsaw, ideally a resaw at timber yard.
I'd get a price there first.
The trouble with old sleepers is the outer layer is packed with embedded grit and small stones which will blunt a chain in seconds.Sounds to me like folk are trying to force the chainsaws to cut. Give the saw time to cut, let it do the work and make sure it is properly sharpened before you start. By properly sharpened I mean fie the cutters and check the raker heights and take them down if need be. I have cut sleepers and it wasn't a problem
A friend of mine ran a permanent way gang (trackworkers) back in the days of British Rail and they used chainsaws on wooden sleepers, I remember seeing a couple of well battered Husqvarna saws in the back of one of the vans.
no chance bits of stone in sleeper would wreck chain in 5 seconds flat. a rather large circular saw with a crap blade would be bestI would say most mills wouldn;t touch them anyway due to the risk of metal.
You'd probably be better with a chainsaw.
If you already have a chainsaw and don't have access to a big circular saw then I'd take the chance with the chainsaw, if it takes a couple of sharpenings then it's cost nowt but a bit of time.no chance bits of stone in sleeper would wreck chain in 5 seconds flat. a rather large circular saw with a crap blade would be best
I look after my gear so I wouldn't use it on them . still everyone to there own I'm not knocking it as long as there happyIf you already have a chainsaw and don't have access to a big circular saw then I'd take the chance with the chainsaw, if it takes a couple of sharpenings then it's cost nowt but a bit of time.
So you wouldn't cut them then? It sounds like something is going to get knackered if your going to cut them so might as well use what you've already got - otherwise you have to buy/hire something to do the job. I guess you'd have to weigh up the cost of a chain vs hiring something.I look after my gear so I wouldn't use it on them . still everyone to there own I'm not knocking it as long as there happy
to do so
