What Martin gets upto.......
  1. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    I thought I'd share projects that I'm doing, mainly restoration and panel making, I just play at it.
    First off is an MGB GT rear lower wing I made this week, I will do it in 3 pieces.
    I'll make a centre section of about 10", so I can planish the weld when it's welded in. Then I'll do the main sections front and back, last because I can get in the back with a dolly and stretch the weld, the plan is to Tig the joint and use no filler when finished.
  2. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    This is the rear lower panel, I wheeled the double curvature shape, hammered in the bumper recess and then turned the flanged.
    It was quite a challenge to keep the correct shape when creating the bumper recess as the panel deforms quite a lot while doing this.
  3. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Front rear quater panel
  4. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    There wasn't any wheeling required on this panel, it was just shaped over a bit of tube, the difficult bit was the double flange for door recess, trying to keep the linear shape required an accurate profile to keep in it check when shrinking and stretching the flange.
    gordon stephenson likes this.
  5. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Trial fit on the car, not bad so far
    eil, james butler, Fintray and 8 others like this.
  6. 500e
    500e Always buy fire insurance a flood is hard to start
    4,574
    SWest UK
    Ace job our Wallace would be impressed:thumbup: he did his time with a body firm that actually made body's from scratch to their or customer their own design, he could lay on a coach finish with a brush that was as good as spraying.
    Maxakarudy likes this.
  7. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    I started off as a coach painter, also became a signwriter, metalwork has always been my real passion
    MattH and brightspark like this.
  8. Cris B
    Cris B Every day welding is a school day
    450
    Sefton
    Lovin' the avatar :D
    Metal work looks fantastic. How advanced is your workshop setup? Do you have a big english wheel setup?
  9. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Avatar sums up my sense of humour:laughing:
    I've got my own sign business and I really indulge myself with all things sheetmetal, Edwards cast wheel, Pullmax, shrinkers/stretchers, all business related of course:D
  10. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Thanks for all the positive comments chaps.:clapping:
    A little more progress..
    I had to repair the front wing, it came with the car, it was brand new so was worth repairing.
    The top & sdes were caved in quite a lot, the blue dye in marking out blue, I use it so the dents are easier to read, like a guide coat on primer
    No magic or camera tricks used, just hammers, dollies , long sanding board and 5 hours of my time
    This is the top of the wing
  11. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    This is the top dollied to shape, 1.5hrs
  12. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Side of wing, a lot of work on this
  13. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Side of wing finished 3.5hrs
    Next is Epoxy time, get the roller out boy!
  14. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    You've gotta check your own work:laughing:
    Wallace and decca like this.
  15. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    BTW, I'm a cluttery person, get used to it!............if I had 10,000sq/ft I'd still not have enough room for my gear:thumbup:
    slim_boy_fat likes this.
  16. Wallace
    Wallace Member
    7,093
    Staines, Middlesex, England.
    Lovely work. I see the avatar extends to the tools too! :D
  17. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    I previously started restoring another MGB GT, these are a few memories of it...:(
  18. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Nah mate, you can't weld the roof up on car, you mad or somefink?
  19. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Yow talkin to moi?
  20. Maxakarudy
    Maxakarudy Member
    323
    West Mids
    Not bad for mig, some say it can't metal finished, wish I knew that before I started, ignorance is bliss sometimes
    eil likes this.
Advertisements
