Tinbasherdan
Bodger in chief
- Bolton, England
We had a grey fergie with a Perkins in and I think every gasket was cornflake packet!
Totally stig of the dump is cornflakes packet ...We had a grey fergie with a Perkins in and I think every gasket was cornflake packet!
Aye but the old lass never leakedTotally stig of the dump is cornflakes packet ...
Thats Spencer with his fancy punches. Good job I didn't mention I use my cnc milling machine with a homemade drag knife mounted in the spindle and draw them in cad and let it cut them out for me.What's wrong with empty cornflakes packet!! Bloody posh boys with your gasket card and wad punches![]()
Probably ran out of oilAye but the old lass never leaked![]()
I use Klinger it always seals.Klinger c4430 it's pretty good stuff ! Used through the the oil industry
im not happy using the liquid gasket options, i have used them before for this application but everytime i have to re-visit the area i have to destroy the gasket and then clean teh mating faces etc.
no, it only appears to show a small part of the cam shaft, but in order to take the valve cover off this plate needs to come off as well as some of the bolts go through it and the valve cover to hold both down. as itsa renault there are numerous reasons for taking it apart quite often, and each time is a different reason...leaks, duff sensors, replaced the cam shafts, and a few valves, a threaded plug blew out of the old valve cover (for no reason at all i might add, nothing bloked causing a pressure build up) so replaced the cover and the panel as one then a while after this i was doing something and noticed 2 of the bolts were loose, realised the threads were stripped and it was leaking, helicoiled them and have been chasing it sinceWhy do you have to 're-visit' this area, is to access the spark plugs?
And there you have it....I try and help people by sticking my two pence worth in....and there is always one that has to stick a good 30 quids worth in with there cnc cutting and cad programs....well I hope it develops dyslexia. ....Thats Spencer with his fancy punches. Good job I didn't mention I use my cnc milling machine with a homemade drag knife mounted in the spindle and draw them in cad and let it cut them out for me.
On the plus side, it works on conflake packets too, but I can't be bothered picking the glossy side off the pack so they seal proper.
You've never livedA big note too all the car development firms through out the world that invest millions and millions of pounds in to gaskets. ..well thanks to fergie and her Perkins and cornflakes you can stuff ya face and fix.produce.repair at a fraction of the cost....View attachment 73874 oh...you get a free pair of scissors with the packet![]()
Greaseproof baking paper is a good, thin gasket material. Are you sure you're not bowing the plate when you tighten it down?
Yes .will it hold up to the oil?
I was told that it did two things by the guy who taught me it first, first it let whatever you coated the gasket with (shellac, varnish, thin sparing smear of rtv etc) to make it oil safe penetrate the cardboard to do its job or it starts to ooze slightly a few months later, and secondly when a box is chucked round the supermarket, its the shiny outside that's more likely to incur scratches and be dented slightly so by removing this layer it improves the chances of sucess.I've made loads of cereal gaskets, none have leaked and I've never heard of picking off the glossy side...
I've always assumed (maybe wrongly) that the fluid it's sealing in get's slightly absorbed and causes the fibres to swell a bit, increasing the seal.
I reckon I'd rather have the chicken staring up at me than "now wash your hands" & that smell of the old disinfectant Izal Medicated every time it warms up.If you want the ultimate material, Izal. That stuff resisted any efforts to break it down or soften it, and it seems impervious to any and all fluids.![]()
