If you took a vehicle that was working fine to a garage to have the timing belt done then I don't think there is any need for discussion, you take it back and tell them to fix it end of.
Thanks for the memory 8ob. I recall making that flywheel tool, All simple stuff, but fool proof. (As with everything I will still have both pins in a "safe place"
Franklin tools do the kit (£30 ish) and chuck in the gadget that holds the pump pulley in place so you can do a pump swap without pulling the timing cover off.
He actually did say why haven't you done it yourself when he was looking at the engine conversion and all the other bits ive done.
I just figured id get it done properly once and not have to worry about it, that hasnt worked too well![]()
Crank pulley- take the wire off the stop solenoid, put a breaker bar on the nut and jam under chassis leg, then give it a quick tickle with the starter. Cracks them every timeWhat?
A bolt for the pump and another bolt for the camshaft really should be all you need. 12 pence.
If you really feel the need to keep the crank still (even though it just stays where it is when the others are in line) then a series reverse light switch works - screw it in, rotate crank until the switch clicks into the slot, done.
Not that you should be turning the crank with the belt off...
Oh, and crank pulley nut - put it in 4th gear, put the handbrake on an extra click and use a breaker (or maybe I just have superhuman strength...)
I wouldn't let the local VW change my summer/winter floor mats. My cars in the shop at the moment being repaired after a bump they looked at me stupid when i told them not to wash it.
Chap at work paid £400 to have his car detailed and told the garage not to wash it when it went in for a service, so they did, with the same bucket of water used on the previous few cars, he was not happy.
My girlfriend worked on service desk at a big name German sports cat brand that begins with P and is similar to a beetle,Chap at work paid £400 to have his car detailed and told the garage not to wash it when it went in for a service, so they did, with the same bucket of water used on the previous few cars, he was not happy.
I've seen it done by my ex boss,Remember seeing Ed China changing a belt by slitting the old belt with a craft knife right around its circumference leaving half in place to fix the timing, slipping on the new belt then cutting off the old one. Has anyone done that?
Small inspection cover off the front of the timing chest cover, you have 3 10mm bolts and I think a 19. Slacken the three 10mm off, then with a bar on the big nut you have a couple degrees each way to fine tune pump timing . Nip the 3 up, and start it. If it runs worse, go the opposite way. Small adjustments are the key. Bit of trial and error will set you right.
No need to retime the whole thing
Just pull the little plate off and tweak it , otherwise you’re going to have to drop the whole timing belt and start again. No need to line anything up, it’s a bit more of a rough and ready solution but if the pumps only just out then it’ll be ok.So, i need to set it to TDC using the notch on the flywheel and the mark,
Then remove the cover plate and see if the locking pin (drill bit) slots in, if it doesnt then rotate it till it does.
I know i should just let them deal with it, but if its that simple then ill just do it myself, itll save me the 70 odd quid in wages ill loose wasting time taking it back.
I know that feeling well get it every time i start the car lately.I do this for a living
Even after 40 years of changing belts I still get the funny feeling in the belly when starting them up
brown trowser moment on start up she was running lumpy
Dip stick was not in properly.
