Wet on wet cycle is usually used when say a primer has flashed and you put say an epoxy over the top, just laying on coats is all wet anyway LOL
2 : 1 plus thinner, may be I'm leaving it to long between coats, bit nervous of it developing runsWhat mix aare you using?
Im under the impression direct gloss Steve.
Ah missed that. Good point.Got those broken screws out btw.
I'm using gloss , I assume thats straight paint. ( its defintly not bse cot clear coat )Which are you using basecoat or straight paint ??? I think there is confusion ?
Ok tried that , Its gone on much better , it looks pretty good, one or two small runs but hopefully I can get them out. I watched a youtube video , where you cover the the run with filler and then flat it back , has anyone tried this ?touch a hidden spot with your finger , if you get wet paint on your finger its not ready , if you just leave a finger print then its ready to go
