Shoggi
- Bradford west yorkshire
Disposable reg it's got numbers 1 to 6You said "gas flow 4" - 4 what?
Is that using a flowmeter, or a peashooter, or the knob on a disposable reg?
In the sip manual it says use between 3/5
I can't seem to find a gauge type regulator for disposable bottlesIn fairness, that could be anything then...
We're can I get a peashooter flowmeter to fit a disposable bottleUsually to get anything like the required gas flow you have to have those regs wound out full bore, and even then it's iffy...
I'd recommend getting a peashooter flowmeter so you can see what's really coming out - from the original pics I'd guess at a slight gas issue.
I just used 240vac fans and wired them to run constantly; something like this, I keep my eye open for broken pub fridges as they always have several 240v fans that can be salvaged. Fitted in the case if there's room or when there's not I folded up a bit of sheet aluminium as a cowl and riveted it on the outside; ideally the fan should blow onto the transformer and the diodes, but as long as it's exchanging the air inside the case it will help.I was told I could not put a cooling fan on it
Do you have any details about were to wire it ect
