I recently had a badly broken Ajax Saw in my workshop, it hadn't started out that way, but a little pressure in the wrong spot removed the rear blade boss from the main overhead arm. Leaving a useless
piece of kit. Now every man and his dog knows you have to clean and prep, then heat up in an oven else you will never weld cast iron for it will just crack up everywhere. Well, that's not strictly true, a friend of mine with stick welding gear followed a way of repair that I had heard of from the states. This involves cast iron rods of course, tack here and there to hold the sheared piece in place and then let it cool, tap the oxide off and leave. Return later and start a small stitch at every tack, less the half an inch, hit the slag off and don't be timmid. Leave and repeat the process until you have built up several compact runs all around the offending repair. My Ajax Saw is now as good as new, a little uglier perhaps, but going strong. It seems that the hits to remove the slag help to distress the metal and the fact that it does not really get that hot due to small stiches is the answer.
