The pipe is 32mm diameter (1 1/4 inch) and the tube is 40×20 mm (1 1/2inch × 3/4inch) and the thickness of both of them is 24 gauge and the wire used is 0.030 inch and weld bead width is 3/16 ~ 1/4 inch !
The second pic is behind the weld bead on pipe
Does anyone know what settings and what technique should be used to weld such a wide and massive weld bead on an extremely thin metal?
Is it welded multi-pass or just one pass?
