Richard.
- Cambridgeshire
Personally I'd split off into 2 on the cap and run stringers. I don't like big wide weaves. They look hideous and have the mechanical properties of a chocolate bar.weave for the cove
With tig the weave is done by cup walking and it’s done like this because it’s way faster than freehand in a prep. That said I quite agree some of them weaves are way OTT on the width and could of been split off into multiple runs and still allowed for a cup walk. The position demands torch manipulation to maintain a profile while fighting gravity but I keep it to a minimum personally and split off as soon as there is sufficient space to do so. Put a 3 run cap up against single run cap on a set of charpies under the same welding conditions and the 3 run will win every time.what is it with tig welders in particular, and massive weaves espectaly some of the FB groups all you ever see is wider and wider weaves to the point you'd think they were stringers run the wrong way,
i've found distortion is much less of an issue with stringers, on some of the repair work much less likely to see repeat breackages near the weld in what would be the HAZ, i recon a good stack of stringers looks better, and i find it easyer to do
Sorry mate I’ve just seen this. I don’t do much with the rutiles either and I had a go with those spezial things the other day and as Brad said they are a bit of a hybrid rod. Advantages from both rutiles and basics but not really either one.@Richard. Can I pick your brains about overhead open root? I am struggling to achieve adequate reinforcement.
