the snooper
getting older by the day
- Hull UK
be a lot of scrappers if it wasTrue. Testing will not be retrospective.
Which is why most testers are going to turn a blind eye i think. If it passes emissions test ok that is.
they will probably call for the standardisation of catsYes this is a grey area! Vosa are not the best at setting guidelines.
Real world scenario... Most mid 90's to early 2000 cars will pass!
eventually the lez will be that strict it will become pedestrian only zone and you will be fine for fartingOne of the better ideas I have seen come from a debate on this forum.
Exhaust cell with chemical cat and DPF filter in one end, made for a flow rate of litres to manage the gasses from a 200hp engine. With a standard removable recyclable (cheap filter element).
Oh... What a good idea!
Call them Euro 5 or 6.
(this is exactly what lorries have to have for the centre of London)
Oi, I thought we were supposed to be moaning about mechanics, not VOSA/DVSA/whatever.....
It is a very sad state of affairs when you can have a tyre with 1.6 mill of tread in the middle section that will pass a test (but has no grip at all on a wet road)
Will pass a test
But a diesel with a DPF that will never work on a low milage car fails
it bugs me that mopeds have no legal limit on tyre treadIt is a very sad state of affairs when you can have a tyre with 1.6 mill of tread in the middle section that will pass a test (but has no grip at all on a wet road)
Will pass a test
DVSA now lolThe laws the authorities come out with cause excessive costs fro the motorist, when the mechanics charge the motorist
If I were VOSA, I would add loads of things to the MOT test (mostly for motorbikes and lorry plating)
And remove somethings on light Class 4 car testing!
On my discovery, the cambelt failed... A previous owner had it replaced at the appropriate time by a land rover specialist. It was about 4,000 miles before it was 'due' again.
When I took it apart to fix it I found, inside the timing case:
This is one of the parts with the least damage:
Well done that un-named "land rover centre", yes, I know who you are because it's in the dis-service book.
Hackney carages and mini busses are 1 millI always thought it was 1mm
LOL
LOL
Where the engine capacity is not greater than 50cc,tread depth may be less than 1mm, if the tread pattern is clearly visible around the entire circumference and across the whole breadth of the tread.I always thought it was 1mm
So what would you add for motorbikes?
