"Stage 8" is the company name . . .I'd reject that based simply on the "Stage 8" label. Stage 8 bolts that "ensure peak performance"- honestly who falls for that crap?
I did not know the threads were tapered. I expect the original studs were M8 turbo end and M10 exhaust side or they had a wider unthreaded center section.Turbo studs and nuts are generally copper coated, the threads are tapered on the studs, they never work loose.
I dont plan on replacing them unless they fall out again!With so many millions of turbos in the world that don't come loose and fall off with standard fasteners I'd just be putting standard ones back on and keep an eye on them. I used A4 stainless on my bike manifold and flat washers and they never fell out.
Don't over-tighten them excessively, or they'll go into plastic stretch when the manifold gets hot then they will come loose when it cools.
Not tapered on any of the turboed cars I've owned. Some have looked tapered due to corrosion.I did not know the threads were tapered. I expect the original studs were M8 turbo end and M10 exhaust side or they had a wider unthreaded center section.
Slightly cheaper
How much are they from the main dealer?
I often find that some of these fancy aftermarket things are a lot more expensive than main dealer prices.
If they’re genuine as mentioned they’ll have marked up the price and then there’s the shipping.
Cheers, I will see how my standard bolts fair first, if they work loose I may try nordlock washers next.If they’re genuine as mentioned they’ll have marked up the price and then there’s the shipping.
I’d give your local Ford parts dept a call if you’ve one close to you it should work out cheaper.
I spoke to the old owner of the car last week he said the bolts that were missing were those super 8 ones with the clips! so they clearly do not work!
Ill try the nordlock next as I have those in the garage. ?if that fails then its drill the heads and use locking wire me thinks
