and meNewer than me...
) and you are sure YOU are going to weld it then the gas issue is one not to rush into as there are some very expensive "no rental" deals around that look ok at first BUT you will probable only be able to REFILL from the place you got the bottle from as MOST other gas suppliers won't fill a bottle that is not theirs. So check but the initial deposit (usually comes as a full bottle) AND the cost of refilling. Remember when the gas runs out how quick can you get it filled ? How much if it's a postal/courier service will that cost. Don't rush to get a new reg as you need to make sure you get the correct type to match the thread type and fitting on the bottle.
Unless Sealey has licenced the TARDIS technology then as far as welding time goes I don't believe you and I don't believe the Sealey catalogue either.
1kg of liquid co2 converts to 19.3 cubic feet at atmospheric pressure - or 546.5 litres.
At the 'normal' mig flow rate of 10 lpm, that'll be 54.65 minutes of welding time.
To get the 3 hours Sealey advertise, you'll need to run at 3 lpm, which simply doesn't work.
(I've slightly rounded a few numbers there, but in all honesty if you get a real actual hour out of one of those with sufficient shielding you're doing well.)
The chap that runs sgs is a member on forum.I really do like the idea of using fire extinguishers past their "use by date" but getting a regular supply of those might be quite tricky. I've been speaking to a chap at work who does welding on his car at home and he suggested a couple of nationwide rent free places in the uk. Has anyone had anyone had any experience with either of these? Personally I prefer the look of SGS gases since there is a local garage nearby that distribute their cylinders. Also *removed for legal reasons* seems to have a deposit which takes into account depreciation of the bottle over time :-/
http://www.sgsgases.co.uk/mig-tig-welding
https://www.*removed for legal reasons*.co.uk/
. So here is what I did:
