ajlelectronics
- Gloucester, England
Fill the system with Mercury instead of water then you can run the rads up to 356.7°c
Neat Glycol aka Evans coolant will allow 160C if I am to be equally silly.
One of the threads I have not read yet.As you might have noticed in the isocyanate fogging thread, if I know what I am talking about from personal experience I give the answer once, then disengage when argued with. It just isn't worth the effort to have a battle of wits when your opponent is clearly unarmed. Reasoned discussion and difference of OPINION are a totally different matter of course.
On that point. I am considering using OAT (or if suitable the cheaper blue stuff) coolant in a central heating system in a static caravan to prevent winter freezing up as the pipes are underneath. They will be insulated but I dont think that would be enough with standard central heating additives.Neat Glycol aka Evans coolant will allow 160C if I am to be equally silly.![]()
The hot/cold pipes will be getting heat trace & insulation fitted which has worked before for my outside pipes.
Its an all new system & no plan to solder any parts so unless the ali boiler has solder thats not an issue but thanks for mentioning it.Bear in mind that OAT is corrosive to solder and many soft metals likely to be found in an older system. Bluecol would be a safer option, or even the aforementioned Evans coolant if you can afford it.
Do they give enough frost protection?Just get the proper central heating stuff, its cheap enough
Adding glycol has an adverse effect on the specific heat transfer of water so would down-rate the heat output.
fit a frost statDo they give enough frost protection?
Dont think that would cover external pipes under the static.fit a frost stat
We are planning on heat trace on all the non heating pipes but assumed antifreeze would be an easier / better solution for the heating system itself.Fit a bit of trace heating tape before the insulation. Only uses a few Watts of power. If you want belt and braces, fit a frost stat to bring just the pump on as a first stage and another set slightly lower to then bring the boiler on.
