I should add ghollan, that copper tip is where the welding wire is connected to the welder for power i.e. if you have the wrong size tip you will have a poor electrical connection, this would explain why you are so far out with the settings. When you weld is it a little erratic and difficult to control? (although my welding still can be even with the correct tip!)
IIRC the hole in the tip should only be 0.008mm to 0.01mm larger than the wire?
