henry Kadzielski
- Australia Wollongong
Good morning gents. My system has auto voltage control for the THC system. We can change the torch height by altering it on the Mach3 screen, it seems to work OK. I can and do set the cut voltage which comes form the cut charts, the speed, pierce delay, leadins and out's and also the air pressure. All is set for the PM125 via the RS485 communications, again all is fine if all is working as it should
. I also can have problems with taper if the nozzle is damaged and it can be damaged easily if the pierce height / delay is not set right or working as it should. When all is working as it should I cut 5sheets of 5mm alli (1830 by 6100) on one nozzle and electrode, when doing the punt previously and recently 4sheets of 6mm (1830 by 6100) on one nozzle and electrode, which translated to quite a few meters of cut and quite a few pierces also. Consumable life, at least for me is not a concern
. I have not changed the swirl ring of the shield from when the system was new and when I started. Also
