OJCar
- Lothian & Westmorland
in the puddle on the floor.The gearbox, engine, and chaincase oils are separate
Someone may have been shocked by the rust in the clutch drum and trying to stop it.
Doesn't it have separate oil for the gearbox? As in is it leaking gearbox or engine oil?
Leaking Engine Oil from the Gearbox?Engine oil, from the output shaft seal which is behind the sprocket, which is behind the cover plate, which is behind the drive dog, which is behind the clutch basket which is behind
Indeed, it's leaking oil from the gearbox output shaft seal. That may or may not actually be gearbox oil.Leaking Engine Oil from the Gearbox?
Shurely shome mistack?
EngineGearbox oil, from the output shaft seal which is behind the sprocket, which is behind the cover plate, which is behind the drive dog, which is behind the clutch basket which is behind ... well you get the idea.![]()
Yes I know! I used to own a T150 and T110 preunit crankcases!EngineGearbox oil, from the output shaft seal which is behind the sprocket, which is behind the cover plate, which is behind the drive dog, which is behind the clutch basket which is behind ... well you get the idea.![]()
There is no seal between gearbox and primary.Indeed, it's leaking oil from the gearbox output shaft seal. That may or may not actually be gearbox oil.
It's also leaking from a number of other places but once the oil's stopped flowing from the output shaft seal which is the main source I'll be able to see how much and hopefully from where.
