Ah, but it's got a moderator too!They'll lock you up, if you use that on carol singers![]()
They actually do!They are Hex-Plus which means they supposedly drive off the wall rather than the corner and allows much more torque to be applied, you can see the shape here.
I do like wera stuff I've never had any problems with anything I've had and their driver bits and holder are excellent too .Must be a day for Allen Keys, just got these ones.
Wanted a decent set so went for these, so hopefully they are good.
They are fine and long, to give an idea of scale the 10mm on is 230mm or approx 9" long.
They also have a ball detent on the long ends.
And it seems to work fine on standard depth hex.
Wera sell imperial hex key sets too. I have some I bought a couple of years ago to go with the multicolour metric setThey actually do!
We have them in metric, it's our goto tool to get scrappy Allen srews out, I don't use them to tighten srews except it's for eternity (LockTide Red e.g..)
Good buy!
Carsten
Very good investment. I don't think I've rounded off any hex hex bolts since
I deliberately went for the normal ends, ball end can be good in some circumstances but they can be a pain when trying to start a screw where access is limited and you are having to try and use the key to get it in place.I have had a set of the ball end version for a couple of years - excellent so far.
They’re cool. What sort of make is bondhus? Not come across them.I deliberately went for the normal ends, ball end can be good in some circumstances but they can be a pain when trying to start a screw where access is limited and you are having to try and use the key to get it in place.
The other set I was thinking about getting was these Bondhus ones.
Decided the Wera Hex-Plus may be better on the shallow sockets that the button heads on the Africa Twin has. They are shallower than normal as Honda has kept the one size head and hex which is what a normal M8 button head would have but they are M6 and even some M5.
I think Bondhus are a top tier make, certainly any I have used have been good. USA made or at least they used to be.They’re cool. What sort of make is bondhus? Not come across them.
I have recently discovered flex head sockets so these hex keys look equal useful
Good -unconditional warranty on tools -that I've never had to use with any of the allen keys or allen drivers I've had of theirs. Not inductrial use, but pretty hard, regular use over the last 17 years for one metric set.They’re cool. What sort of make is bondhus? Not come across them.
