25.4_mechanic
- Germany, southwest
Aye, I tend to avoid a lot of USA Youtube content, tends to be full of, as we say here, wind and p*ss. I haven't watched the video but it just came up in a search and looked similar.Watched the video.
I don't know if it's a typical US close: Read German and think military.
On the much closer thought of fence building he did not come at all.
At the end of the video you can see the stamping in closeup.
" eumschüssel - ermany".
This seems to stand for: "Reumschüssel - Germany"
There was a pliers factory Oskar Reumschüssel & Co.
in Hauptstraße 33, Steinbach-Hallenberg, Thuringia (this would become part of the later GDR)
Source: The German Tool Industry - 1940
His tool really seems to be much more noble: with me the handle has no knurling, but the hammer is more pronounced, my tool also seems to be altogether larger one, no marking.
Carsten
Why are men always bragging about tool sizes?His tool really seems to be much more noble: with me the handle has no knurling, but the hammer is more pronounced, my tool also seems to be altogether larger one, no marking.
Carsten
 but I also said:
 but I also said:with me the handle has no knurling
You should have asked me just after I posted, afraid I have been trying to find out what a fault code on the boss's V40 is and I can't remember, probably the thought of the expense, bloody carsWhat was your search term, if I may ask?
Carsten
Its a metaphor for being a hundred kilos of dynamite with a half inch fuse.Why are men always bragging about tool sizes?
You are lucky, I still had the window open. So here is what I searched for.What was your search term, if I may ask?
Carsten
That way madness lays.In the meantime I found some more with "old german multi tool".
Anything can be used as a hammer if you look at it long enough.Farmers tool, so basically fencing pliers for hashing and bashing as farmers tend to do
Aye and Farmers and Fishermen look long and hard at things.Anything can be used as a hammer if you look at it long enough.
Saves a long and tedious trudge or swim back to the base for an item.Aye and Farmers and Fishermen look long and hard at things.
No, sadly it means I have to sort out a hashed and bashed lump before I can even start to repair the initial problemSaves a long and tedious trudge or swim back to the base for an item.
If you can’t fix it with a lump hammer or a gas axe, you’ve got an electrical problemAye and Farmers and Fishermen look long and hard at things.
They are even worse the further North you go, spent a few summers up in Caithness.If you can’t fix it with a lump hammer or a gas axe, you’ve got an electrical problem
I am in the same ‘boat’ as hood. I often have to take a lot of steps backwards to get to the original problem before I can go forward. I put a set of work lights on a tractor today. After getting rid of the farmer boy hillbilly wiring I’d basically required the damn thing!!
