Last of the big spenders.Nice haul, though.
1" drive (that will make sorting the tractor wheels out easier)
It's air powered, no idea what the connector isIs that an hydraulic or air connector?![]()
There'd need to be a second, return connector if it were hydraulic. For the air that must consume I'd expect you'd want to swap out whatever that connector is for a big claw style coupling.Is that an hydraulic or air connector?![]()
All for 24 pounds.
I have a free painless cure.
.Getting fed up trying to sweep sawdust off block paving and lawns
Grabbed this bare and it arrived today
Got home after a very hot day on scaffolding in direct sun
Unzipped my flies and gave it a test
Yup. Cures sweaty balls
Is it one speed or variable, and possibly be adaptable to use with a forge ?Getting fed up trying to sweep sawdust off block paving and lawns
Grabbed this bare and it arrived today ……………………………….
Wife's got a video I can upload if you want. She was most amused.pictures are not needed to prove this
3 speed on a switch and speed sensitive trigger too.Is it one speed, or could it be adapted to use with a forge ?
Interesting, will have to look into it. Thanks.3 speed on a switch and speed sensitive trigger too.
Oh and a trigger lock
You know that you can adjust the blast by partially covering the intake or outlet, yes?
