daleyd
- Wrexham, North Wales
or will heYou'll be gutted if you open them and find cans of Ace lager inside...![]()
I've already found a solution.Most of the time on AliExpress they either give you a refund and say just keep it for low value or partial refund for high value as costs them more to return it even if you want a full refund
Cor, a proper lube bay.
I've fitted similar to take the cast out of welding wire to reduce tip wear (keyholing)Today after being in the post for a month I acquired a tube straightener.
Link!
Bob
Very good at what it does.
Jammy git!
Have you been hunting around derelict buildings
If there's an air one spare 1st dibs please!
What other goodies have been left abandoned there!
Every pipe straightener post has someone saying this in response but I'm yet to see anyone post the resultsA six inch length of broom handle drilled through lengthways with a 5mm hole works just as well.
Next time I do a MI fire alarm install I will post images.Every pipe straightener post has someone saying this in response but I'm yet to see anyone post the results
Straighten the pipe before fitting the pipe nuts and flaring. I very rarely ever need anything bigger than 3/16” .Cant see a broomhandle covering the range of pipe sizes that one will cover and how do you get a broom handle on/off a bit of pipe that needs straightening once the fittings are on
Bob![]()
