cornflakeMini
- Bedfordshire, UK
... that is the question!
I have an Aluminium intercooler with a cracked mounting bracket which I'd like to repair.
The bracket is around 2-3mm but I would guess that the wall thickness on the intercooler is closer to 1-2mm. I can't be certain of the intercooler wall thickness as I don't want to cut into it ideally.
I'm considering buying an AC TIG to do this job but would appreciate your opinions on whether it might be possible with MIG?
I've never worked with Aluminium before but I have a good amount of experience MIG welding thin steel (0.8mm) and some limited experience TIG welding thick steel (2 - 3mm).
I already have a bottle of Argon so it might be cheap/easy to take a punt with MIG if I stand half a chance.
I normally use a SIP Migmate 100 although I can get access to a 160A MIG welder if current will be a limiting factor.
Here's a picture of the job as well in case it helps:
Thanks in advance everyone!
