Richard.
- Cambridgeshire
I don't think your cooler is saving your torches any more than a standard cooler unless the cooler is not running or run empty etc then even the speedways will die quickly if used without water. I'm not an expert but in my life of torch failures it's usually 2 common places. Hot and cold cycles followed by rapping and flexing causes inferior rubber hoses to crack, perrish and leak and the second one is the soft copper pipes in the neck will only cope with so much strain and a couple slight bends before they eventually snap. Copper cables discolour and corrode if not used with the correct solution but the speedway deals with this better too with the coated copper cables. I think it's a case of deciding the needs from a torch. I weld more Alu than anything else from 1-5mm (30-200amps ac) which is highly stressful on all wp20 torches, the speedway is still newish so I can't go on to say it's the best thing ever yet but so far it's not struggling with all the ac I throw at it. I had a cs310 wc for 2 years before this which I sold to a forum member in perfect nick which got some serious ac abuse.Maybe I am one of the lucky ones as I have never had a cheaper torch fail!!!!!
Maybe it's my Lorch water cooler that's switches it's self on !!!!!!!!!
