here is a lower power version of the same unit..
http://www.ebay.co.uk/itm/171324428554?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
And the procons were made precisely for that job.Yes, that is what I was meaning by Chinese pump. I tried one after I tried the CH pump and it was an improvement. I had to put a diverter valve in to reduce the pressure as it was way over 100PSI but with doing so the flow was then reduced to, if I recall 800ml/min. I have no doubt whatsoever though that if I now tried it with the blockage in the pump removed that it would work great but as I now have the procon I will use that as it is certainly a lot quieter than the Chinese pump and no need for a 12v power supply.
As said mine doesn't have a protruding shaft, see pic. Could be done by making a shaft up and a housing, would need bearings etc so much easier to just bolt a fan on the outside of the cooler I have now as it already has a place for a fan, see second pic.Like so but instead of using it as a fan for the rad like this person you could turn it round and use it to cool the motor.
That's the same pump the guys were using. Another member built his cooler using one and it's still going.here is a lower power version of the same unit..
Your torch was blocked at the time. This will cause the pressure to build up higher than normal and cause the poor little motor to be overworked and get hot.That is the one I had, way over 100PSI when I tried it so as mentioned had to reduce by diverting some of the water.
Originally I used the screw on the end to reduce the pressure, basically it is a limit switch that cuts the motors power when a set pressure is reached. With doing it that way however the motor got extremely hot in a short space of time.
Bet you if you tried it now the pressure would read lower, the motor would run cooler and the flow rate obviously will be higher.
)You'll only need one fan for the exchanger. Can't imagine that motor is going to get that hot personally.Sound. Ill get one ordered up. The Heat exchanger, Pump, IN and EX Fans will be in the same chamber. Im hoping the EX Fan will pull air past the pump to help keep it cool.
Sounds interesting stuff Giz. Look forward to seeing it.Don't worry Richard. I will certainly do a build post/ How-to when i get round to it. I will be adding a couple of Gauges as well to compliment the setup.
It appears to be doing the job mate.Ok temporary test setup in the old cooler tank with fan fitted on the outside. I can not place the motor fully into the fans airflow as the tanks output is behind the motor but it is about 2/3 in the airflow.
So first pic showing before I start, only had one temp gauge with probe on motor but as can just about be seen temp of motor is 20.5 degrees.
Second pic shows it after running for about 1.5hrs, motor is now 52.8 degrees and has been sitting at that for over an hour so seems constant at that. I also placed a probe into a hole in the pump, temp is 21.1 degrees so basically it has stayed the same as the motor was before it was started, looks like the fan is stopping the pump from getting heated by the motor.
Will have to put a valve in the line to the gauge when I make it, just to damp it.You'll only need one fan for the exchanger. Can't imagine that motor is going to get that hot personally.
Hope you make your tank out of nice Alu or stainless seen as you've made a couple tanks now.
You can power that motor from a cheap eBay switching 12v power supply. Just make sure it's over rated for it.
Make sure you put your build progress up on the forum too.
What you thinking about. Is it a daily use business asset.
I'd look at your options sooner rather than later. Borrow if you have too. The reason been as good as that unit has been to you it's still very much a £500 hobby unit designed for switching on once a week for a mess about. It's not an 8 hour a day machine and if it fails I'm assuming your out of work and up the creek.It is yes. Ideally something with Pulse. Unfortunately i'm only just keeping my head above the water. so i may have to persevere for a whilst yet.
