But they do have limitations. As mentioned, soft...... (a bigger, longer one can help).
Sweet. I'm even managing to get the blame lain elsewhere now too.![]()
My fat thumbs is how! Sorry, @slim_boy_fat - blame squarely back at @MattF ’s door!!I wondered how I was dragged into it.![]()
I think I used these for the first time the other day to refix my daughters front door? B&q didn't call them thunderbolts though?
Also a fan. The time saved is immense. Bit like Tek screws.
But they do have limitations. As mentioned, soft substrate (a bigger, longer one can help)
But they're also susceptible to fail if used somewhere impacts/vibration occur. Similar to Rawl bolts but worse. If they fail in this situation, it generally means I didn't use enough to spread the impact loading.
They don't fail if they are fitted properly. I was using M12 thunderbolts to support vertical 6-ton pre-cast concrete panels for demolition - 5 floors up on the edge of the building. Didn't have a single one come loose even re-used ones.
As said previously in the thread - use a new drill of the proper size, and a proper drilling machine not some light-hitting high speed job that's going to churn the dust about in the hole and make it oversize. You want to drill the hole quickly. Get the dust out of the hole and use good quality bolts. Fit them with an impact gun.
