Interesting. Does it throw up any code if you try with it switched off? Or does it just not arc up?I’m not at my workshop today but the water cooler on mine has to be running before it’s possible to tig weld with it
That's awesome, thankyou!I have managed to get in today. Without the cooler running nothing happens when the torch trigger is activated.
Pins 1 and 2 in the rear connector b3 are connected together when the cooler is running. For the 250 ac/dc version
Hi Tubo - I've just bought a 150 TE off ebay and was wondering if you would be kind enough to send me the user manual for it - seems simple enough but you always learn something if you RTFMI have a 150 TE that looks nearly identical to that. It welds tig nicely, the hf is great & the mma is great too but I can't get it to run 7018's nicely.
Changing settings using the touch panel is confusing as each button does more than one thing, for example setting preflow & postflow.
I have a copy of the manual somewhere, I can send you the file. I got it by e-mailing TA with my welder details & serial no.
Thread here https://www.mig-welding.co.uk/forum/threads/help-with-thermal-arc-150-te.57523/#post-699616
