Tailstock bit low
  1. spencer 427 Member
    6,925
    uk colchester
    Typical of old machinery...most of em are worn in the usual places
  2. jordan1 Member
    2,054
    Yorkshire England
    Like the rest of us:whistle:
    MattF, fizzy, Morrisman and 3 others like this.
  3. spencer 427 Member
    6,925
    uk colchester
    Speak for yourself lol
  4. slim_boy_fat
    slim_boy_fat Forum Supporter
    Looks to be supported near the end? :dontknow:
    fizzy likes this.
  5. fizzy Member
    6,357
    uk
    Happy days.
    Just checked the tailstock. It is equal from one end of the lathe to the other.
    So obviously it is the tailstock itself slightly worn not the bed :hug:
    So now if I shim it there should be no variation from one end to the other.
    This was my setup hope I am doing it right?
  6. Pete.
    Pete. Member
    9,408
    Kent, UK
    Shimming the body up from the base it quite proper. First you should do a suite of checks to see where you're at. A 2-collar test to check how low you are. A sweep along the top of the extended quill to check how much nod down you have. The tailstock ways are least worn up near the chuck so that's where to check it. Put your mag base on the headstock and the DTI on top of the quill then move the tailstock towards the headstock and watch the dial change. Once you have those two figures you can figure out how much shim to use front and rear.
    fizzy and WorkshopChris like this.
  7. WorkshopChris
    WorkshopChris Forum Supporter
    4,925
    South East Essex
    How much does that height change as you wind the tailstock in and out?
    fizzy likes this.
  8. fizzy Member
    6,357
    uk
    Haven't checked that yet. Locked the quill in that position so measured the same.
Advertisements
