Correct me if I am wrong but you flick switch to off then set your gas flow, then because you might forget to turn switch back on you want a lamp to show you that the wire feed motor is still off. Surely as soon as you try to weld you will find that the wire is not feeding!! You are making this harder than it needs to be. Get a switch that can be seen at a distance that it is UP or DOWN.
