Stueeee
Old git
- N W Kent
Doing a job today of setting in some M10 studs. I had an unopened tube of resin on the shelf. After I'd finished setting in the studs and used some resin to fill some non structural cracks I discovered that the central activator bit of the tube had gone totally solid up by the nozzle and activator started coming out the back of the tube just as I finished. So I have pumped in a load of resin that will never set. It is going to be an absolute sod to get every last bit of it out, but I reasoned that pumping in the same resin with the activator in it should set any tiny amounts that might remain in the nooks and crannies. Then I discovered that Screwfix and Toolstation only stock 'Styrene free' resin now. is the Styrene based resin stuff still available?
.............................. hth
