I've never personally had any specific issues with Masters/Movanos, but have had the occasional vehicle that won't start, and it's likely to do with modules not powering up correctly.I think with the Renault/vauxhall at least, it is something built into the system to protect itself, either from hashed jump starting or maybe a theft immobiliser. It's definitely there as they fire straight up after following the procedure. But nothing is broken as they run fine afterwards. And it always happens after an attempt to jump start them.
Volvos have a "hot" power point in the boot...intended to run a fridge for example I think. I used to just have a solar panel plugged in and stuck on the rear window....worked very well. When the battery is nicely topped up it started lovely....car could be left indefinitely which was very handy.I now leave it connected to a Noco trickle charger most nights.
The only issues I've ever seen have been the result of leads being connected wrong, or in the wrong place.
Either not enough power to fully power up, or some modules managing to power up while others don't so communication between the modules isn't working how it should, and they'll just not respond correctly.
Usually locking the vehicle, leaving it a couple minutes, then trying again is enough to let things shut down, then power up correctly.
If that's the case, then you have a problem - no vehicle 'modern' or otherwise, should draw >50mA quiescent current, usually much lower, around 30mA. I'd suggest you have the cause investigated whilst it's still in warranty, the good thing is that there should be comprehensive battery monitoring stats available to confirm the concern and point to the cause - which may well be the starter battery itself.My 2023 car is loaded with electronics, which is what causes the battery to drain in the first place! Started it with the Noco booster probably ten times with no ill effects.
So that’s another vote for not running a modern vehicle then. I’ll stick with my 24 year old Landrover with no fancy electronics then thank you.
I must have been lucky I use my 2016 relay to jump start tractors loaders most weeks.The X290 Ducato / Boxer / Relay series of vans are notorious for any sort of voltage upset killing the airbag ECU.
They are widely used as a base for motorhomes, and the problem often manifests itself when someone tries to crank a camper van/motorhome with a low battery (from standing unused). There have also been incidents (reported on motorhome forums) that if you give a jump start to another vehicle with one of these, then your airbag ECU can get damaged. In my case (2018 Relay) I killed the airbag ECU by almost stalling the van, such that all the dash lights came on - the airbag light never went off again- £400, please.
The newer (2020 on???) Airbag ECU modules are supposedly more robust.
I’d be a banging on the main sdealers door if my one year old car kept flattening its battery overnight.My 2023 car is loaded with electronics, which is what causes the battery to drain in the first place! Started it with the Noco booster probably ten times with no ill effects.
That's wrong surely!My 2023 car is loaded with electronics, which is what causes the battery to drain in the first place! Started it with the Noco booster probably ten times with no ill effects.
Yes always dead battery last connection. Here's what happens if you get it wrong.I thought the fairy story about connecting the - Neg to the engine/body was to keep it away from the battery to avoid a spark igniting any hydrogen escaping from the battery.
40 years in the motor trade and jump started 100s of cars straight to the battery with jump leads/ battery packs. Never had a problem.
The engine bay of my similar age 106 looks very similar to that Pug – and I can see very similar electronics on the end of the engine I think. Those “fancy” electronics failed one day leaving work, causing me to need to spend 15 miles tied to the back of an AA van.my noco went flat the other day so i had to jump the talbot, can say with confidence neither of these have any fancy electronics
