There are a lot of Starlink satellites in orbit now. Looking at the amount of tree cover, a Starlink "dish" flush with, or slightly above the ridge of the roof will probably have no major issues in getting reasonable data rates.It is the deep narrow valley that is my concern. Satellites will pretty much have to be directly overhead - we don't see a lot of the sky.
Starlink uses POE and comes with well over 10 metres of cable, but to get 50 metres away will require additional cable, which has bespoke connectors, and is not cheap.Do they use power over ethernet? I suspect the best place for us would be in the field right in the middle about 50 yards away.
Well starlink came - tests seem pretty good BUT2 days for me
They seem to have designed it for people to use their phones over wifi. It doesnt allow you to control DHCP
It gives out it's own ip address but there is no way to configure it to work on a typical network. Why is everything so dumbed down these days![]()
Yes can work around it but wouldn't have cost any more to get it right.First thing I did once setup was put it in bypass mode and plug my Gl.iNet router back in
There is a "hidden" status page at 192.168.100.1 but you are correct that there isn't a proper admin
Having said that, if you "need" to configure DHCP you are not running a typical network and should be using it as a pure modem, or bypass mode as they call it
Getting good speeds around 350mbp but time will tell how much dropped signal there will be.
Good deal. No contract and free 30 day trial.
Also free professional installation. Better than our lashup
