steveo3002
yeah be mindfull to keep the primered panels warm and dry as it can suck up moisture and cause the blisters , i always used to try and bake the preped panels on a low for a while incase they were holding any moisture
This will probably sound a bit dodgy but in winter I section off my workshop where the woodstove is if I'm doing any spraying. I crank the stove up so the whole place is warm and when I'm spraying I crack the workshop door open a bit and the woodstove works as an excellent exhaust fan as well. I have two little stove fans on top of the stove and this also seems to help.
If you do go this way be sure and get the short wave infra red.You could get yourself some of the infra red electric heaters that the pro shops use to speed drying times.
