tbone455ci
New Member
- Ireland, Co Donegal
Hi, new to this great forum but can't find the awnser to my problem......
I have a Snap On 130 Turbo mig. I'm not sure if I need the gas regulator that goes on the bottle or tye gas valve that is attached to the trigger?
Haven't used the Mig for over a year, started it the other day & gas was leaking out of the bottle regulator, so I put ptfe tape on the gauge thread & the valve thread where it joins on top of the regulator. (not on the bottle thread)
This cured the leaks but now the trigger was very stiff, after a bit of welding gas started coming out of the trigger mechanism.
I took it apart & the plastic on the back of the brass gas valve assembly had come out of the block, refited & it popped of again.
I then cable tied the plastic to the brass block to test it, which sealed the leak but then the plastic gas pipe & connector blew of the regulator on the gas bottle?
Do I need the gas bottle regulator and or the complete torch neck and gas valve assembly?
Thanks for any help
Sent from my HTC
Thanks for any help
Sent from my HTC
it should be a low soft hiss. if its loud and sharp then a new regulator is in order.
that the regulator is gone, as the trigger getting pressurized & then blowing the pipe of the regulator....
& the ebay links & all the info, real glad i found this forum....
was hoping to finish my bit of welding and use the 2 mini gas bottles I have before doing the euro torch conversion
